Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Pickup
Engine
Symptoms
Not Running
Looking for switch
1986 TOYOTA PICKUP
277,327 MILES • 4 CYL • 4WD • MANUAL
RMAHAN
MEMBER
Truck will not start I'm thinking clutch saftey switch not sure where it is located at on truck what it looks like
Jan 8, 2016 at 9:19 AM
WRENCHTECH
Experienced Mechanic
Jan 8, 2016 at 9:16 PM
RMAHAN
MEMBER
Thank you very much is there a way to bypass it if so how
Jan 8, 2016 at 9:20 PM
WRENCHTECH
Sorry, we don't instruct people on how to eliminate safety features.
Jan 8, 2016 at 9:22 PM
RMAHAN
MEMBER
OK thank you
Jan 8, 2016 at 9:24 PM
RMAHAN
MEMBER
Is there a way to check the clutch saftey switch
Jan 10, 2016 at 2:14 AM
WRENCHTECH
Check to see if you have a power signal turn to a ground signal on the Black with red wire when the clutch is depressed.
Jan 10, 2016 at 3:01 AM
RMAHAN
MEMBER
Thank you
Jan 10, 2016 at 3:02 AM
WRENCHTECH
Those tests are done with the key held in the start position
Jan 10, 2016 at 3:05 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
