Where can i find part shift solenoid 1 with clipping on the side and 1 pin connection?
2001 TOYOTA COROLLA
270,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
RAMDANY SUDESH
Looking for shift solenoid 1 BC 22ES Nachi with clipping on the side 1 pin connection.
Dec 7, 2023 at 11:45 AM
  • 55,433 POSTS
You might need to get a rebuilt valve body which included the part, sometimes only transmissions rebuilders are the only one that can get these parts. You can try Rockauto.com or call a local transmission rebuilder in your area.
Dec 8, 2023 at 3:57 AM
RAMDANY SUDESH
Thank you dear,
There are no transmission rebuilders in my area, and I need to purchase the solenoid online and I cannot get the right part number to select the right solenoid. I changed the gearbox in the past and don't know the model of transmission as the clips are different from the original gearbox 2001. Part no BC 22ES on it NACHI.
Dec 8, 2023 at 2:24 PM
  • 55,433 POSTS
I am not sure where to get the parts for this, did you try Ebay? Also, you can call the dealer, they might have information on where you can find it.
Dec 9, 2023 at 1:02 AM
RAMDANY SUDESH
I tried on Ebay but need part number, which i don't have and no idea as the gearbox is not the original one.
Dec 9, 2023 at 2:25 AM
  • 55,433 POSTS
It looks like the part was a number on it? Does it not work or?
Dec 11, 2023 at 1:04 AM
RAMDANY SUDESH
BC 22ES Nachi on the solenoid but can not find any reference with the number.
Dec 12, 2023 at 1:16 PM
  • 55,433 POSTS
The only thing I can tell you is to call the dealer to see if they can help. Sorry I wasn't more help with this issue.
Dec 14, 2023 at 2:51 AM
