What do these codes mean PO128, PO300, and PO440?
180,000 MILES • 2WD • AUTOMATIC
JERRYKAUFFMAN
I got the codes read, and I was told to Google the results, but no luck! I have PO128, PO300, and PO440. Thanks!
Jul 2, 2021 at 1:56 AM
Good evening,
The 128 is for the thermostat. It looks like it may be stuck open not allow the engine temperature to reach normal operating temperature. I would replace the thermostat.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
The 300 is for a misfire. The most common cause is low fuel pressure from a bad fuel pump. I would check the actual pressure to be sure it is working correctly. I attached guides for you to follow as well. You can rent a tester at a parts store.
Fuel System Pressure
Key On Engine Off 53-59 PSI.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
The 440 is for the canister vent valve in the emissions. It is stuck open causing a large leak. I posted the location and procedure below.
I attached the procedures below for you. of the fuel pump and thermostat.
Jul 2, 2021 at 8:38 AM
JERRYKAUFFMAN
Thanks, Roy!! God bless you!
Jul 3, 2021 at 4:06 AM
You are welcome.
Always glad to help.
Jul 3, 2021 at 4:15 AM
