If i let truck sit for a day or so the battery would drain. And now i drain the battery starting truck most times. And if it starts it takes a 20 second crank and most times with starting fluid. I am thinking fuel or spark? Have not tried anything yet. Note: if i use a battery charger you plug in it cranks slow but if i use a little booster it cranks good and fast, but still needs starting fluid and takes about 10 to 20 seconds to start. Okay, so after i get it running it drives okay even with lights on but if you turn off and try to start almost all the time no start and that's only after a few minutes.
Jan 29, 2021 at 11:07 AM
