long cranks, shuts off at idle after a couple minutes usually
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
PACKERS27
  • 207 POSTS
My truck does not always require foot to floor when cranking but most of the time it does. I have noticed that when it doesn't, you can cut the truck off and crank it back no problem and continue to do it with no gas given. I once seen a P0101 MAF code and a P1072 and p0175 (both banks rich). I replaced the MAF sensor and haven't seen any codes since. I also replaced the MAP sensor as well and check pressure at the fuel rail. Pressure was 50 on key turn and 48 at idle. I don't have any codes. Any ideas?
Nov 1, 2020 at 2:40 AM
  • 110,246 POSTS
The idea that you have to press the throttle indicates a flooding condition. By pressing the throttle to the floor turns off injection. I suspect there is either a problem with a leaking injector or injectors. That would justify the rich fuel mixture as well.
When you checked the fuel pressure, were you experiencing the problem? I'm asking simply because it seems sporadic.
Also, when you pulled the vacuum hose off the fuel pressure regulator, was there any evidence of fuel in the vacuum hose?
By the way, did you mean P0172 above or did you mean 1072. I find nothing under P1072.
Nov 1, 2020 at 9:15 AM
PACKERS27
  • 207 POSTS
It's P0172. Bank 1 running rich. The other code was the same for bank 2.
When I pulled the vacuum line off of the fuel regulator, it was spitting just a little bit of gas but it wasn't just gushing. Sounds like the motor bogged down a little but still running.
When I checked the pressure at the rail, I had to put the pedal to the floor so I could check it at idle, so I believe it was doing it at that time.
Nov 1, 2020 at 11:24 AM
  • 110,246 POSTS
You shouldn't see any fuel from the vacuum hose. That is an indicator that the diaphragm is bad in the regulator. That would result in fuel pressure that is all over the place. Chances are the fuel system is building high pressure, causing the rich fuel mixture, and the added raw fuel is being drawn into the intake via the vacuum hose.
I would recommend replacing the fuel pressure regulator. I feel this is the likely problem.
Here are the directions. The attached pics correlate with the directions.
_________________________________
2000 GMC Truck C 1500 Truck 2WD V8-5.3L VIN T
Fuel Pressure Regulator Replacement
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pressure Regulator Service and Repair Procedures Fuel Pressure Regulator Replacement
FUEL PRESSURE REGULATOR REPLACEMENT
REMOVAL PROCEDURE
CAUTION: Refer to the Battery Disconnect Caution in Cautions and Notices.
pic 1
1. Disconnect the negative battery cable.
2. Remove the engine sight shield.
3. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
pic 2
4. Disconnect the fuel pressure regulator vacuum line.
5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area.
6. Remove the fuel pressure regulator retainer (8).
7. Remove the fuel pressure regulator (9) from the fuel pressure regulator housing.
INSTALLATION PROCEDURE
pic 3
1. Install the backup ring (10) on the fuel pressure regulator (9).
2. Install the new large O-ring (11) on the fuel pressure regulator.
3. Install the regulator filter (12) on the fuel pressure regulator.
4. Install the new small O-ring (13) on the fuel pressure regulator.
5. Lubricate the fuel pressure regulator large O-ring and the small O-ring with clean engine oil.
6. Push the fuel pressure regulator into the regulator housing on the fuel rail.
7. Install a new fuel pressure regulator retainer (8).
8. Connect the fuel pressure regulator vacuum line.
pic 4
9. Connect the negative battery cable.
10. Tighten the fuel filler cap.
11. Inspect for leaks.
11.1.Turn ON the ignition for 2 seconds.
11.2.Turn OFF the ignition for 10 seconds.
11.3.Turn ON the ignition.
11.4.Inspect for fuel leaks.
12. Install the engine sight shield.
Try this and let me know the results. Please feel free to ask questions if you have them.
Nov 1, 2020 at 12:06 PM
PACKERS27
  • 207 POSTS
I installed the regulator yesterday. I didn't get the chance to install the fuel filter yet though. Anyway, the truck is cranking up perfectly fine now and the P0172 (bank 1 rich) code is gone. The P0175 is still there.(bank 2 rich). I forgot to tell you about the random misfire code, prior to changing regulator. That code is gone too. Just the p0175. The truck is running great but what is up with this code man?
Nov 3, 2020 at 1:43 AM
PACKERS27
  • 207 POSTS
Here's what my cheap scanner says:
P0175
Closed Loop
Load % 10.6
Etc 192
Short ft1 1.6
Long ft1 -9.4
Shirt ft 2 -3.1
Long ft2 -10.9
MAP (inHg) 17.4
RPM 1299
VSS mph 29
MAF (lb/min) 3.594
TP % 12.9
Nov 3, 2020 at 1:47 AM
  • 110,246 POSTS
Were the misfires on cylinders 2 and 4? It would have been a P0302, P0304, or a random, p0300.
If it was, we need to do a fuel injector balance test. It is possible to misfuel an entire bank of the engine, causing multiple cylinders on the same bank to misfire even though the root cause is a single fuel injector.
Next, is there any chance water from the AC evaporator dripping on the connector can be causing a problem. Check for that.
If you can, switch the o2 sensors between bank 1 and bank 2 to see if it changes the code to the opposite bank.
Also, if there is a restriction in the exhaust, it can cause this code to appear. However, in most cases, you will experience a power loss.
Not being there makes it difficult. However, (and I can be wrong), I have a feeling it has to do with a faulty injector. Checking fuel injector balance does require a scan tool which can actuate different components. I don't know if you can get your hands on one.
Fuel Injector Balance Test With Tech 2
Vehicle Powertrain Management Computers and Control Systems Testing and Inspection Component Tests and General Diagnostics Fuel Injector Balance Test Fuel Injector Balance Test With Tech 2
FUEL INJECTOR BALANCE TEST WITH TECH 2
Diagnostic Chart (Part 1 Of 2)
pic 1
Diagnostic Chart (Part 2 Of 2)
pic 2
CIRCUIT DESCRIPTION
The scan tool first energizes the fuel pump and then the injectors for a precise amount of time allowing a measured amount of fuel into the manifold. This causes a drop in system fuel pressure that can be recorded and used to compare each injector.
TEST DESCRIPTION
CAUTION: Refer to Shop Towel Fuel Leak Caution in Service Precautions.
4. The engine coolant temperature must be below the operating temperature in order to avoid irregular fuel pressure readings due to hot soak fuel boiling.
5. The fuel pressure should be within the specified range. If the fuel pressure is not within the specified range, refer to Fuel System Diagnosis. See: Computers and Control Systems > Component Tests and General Diagnostics
6. The fuel pressure should reach a steady value. If the fuel pressure does not reach a steady value, refer to Fuel System Diagnosis. See: Computers and Control Systems > Component Tests and General Diagnostics
7. If the pressure drop value for each fuel injector is within 10 kPa (1.5 psi) of the average pressure drop value, the fuel injectors are flowing properly. Calculate the pressure drop value for each fuel injector by subtracting the second pressure reading from the first pressure reading
Let me know if this helps or if you have any questions.
Nov 3, 2020 at 11:09 AM
