Long cranking after truck sits for a while
200,000 MILES • 2.7L • 4 CYL • 4WD • AUTOMATIC
DOUGANDLAURA44
  • 16 POSTS
Just changes fuel filter, air filter, and oil and oil filter. Truck was taking forever to start. Would crank sometimes 45 seconds before it started to fire. Once it does catch I have to continue holding the starter and hold the pedal to the floor. It runs rough for about 30 seconds until I rev it up a few times then runs great. If it’s warm, it fires right up. If it’s sat for a few hours it takes 45 seconds plus to crank and start again. I tried to test the fuel pressure but I don’t know where on the inlet line to connect. I do not have an adapter. Could it be fuel pressure regulator because I have plenty of fuel coming through the return line?
Nov 11, 2020 at 10:25 AM
  • 110,246 POSTS
It sounds like you are getting too much fuel. When you hold the pedal to the floor, the injectors shut down to eliminate a flooding issue. Is it possible for you to make a video with your phone of what it is doing so I can see it? Also, is there a smell of raw fuel when it does finally start?
_____________________________
Here are the directions specific to testing fuel pressure on this vehicle. Note that there is no schrader valve to connect the gauge. You need to do it at the fuel line. See the attached pics.
1997 Toyota Truck Tacoma Extra Cab 4WD L4-2693cc 2.7L DOHC MFI
Component Tests and General Diagnostics
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Testing and Inspection Component Tests and General Diagnostics
COMPONENT TESTS AND GENERAL DIAGNOSTICS
FUEL PRESSURE INSPECTION
1. INSPECT FUEL PRESSURE
(a)Check that the battery positive voltage is above 12 volts.
(b)Disconnect the negative (-) terminal cable from the battery.
pic 1
(c)Remove the union bolt and 2 gaskets, and disconnect the fuel inlet pipe from the delivery pipe.
HINT:
- Put a suitable container or shop rag under the delivery pipe.
- Slowly loosen the union bolt.
pic 2
(d)Install the fuel inlet pipe and SST (pressure gauge) to the delivery pipe with the 3 gaskets and SST (union bolt).SST 09268-45012
Torque: 29 N.m (300 kgf.cm, 22 ft.lbf)
(e)Wipe off any splattered gasoline.
pic 3
(f)Connect the Toyota hand-held tester to the DLC3.
(g)Turn the ignition switch on and Toyota hand-held tester main switch on.
Notice: Do not start the engine.
(h)Select the active test mode on the Toyota hand-held tester.
(i)Please refer to the Toyota hand - held tester operator 5 manual for further details.
(j)If you have no Toyota hand-held tester, connect the positive (+) and negative (-) leads from the battery to the fuel pump connector.
(k)Reconnect the negative (-) terminal cable to the battery.
(l)Turn the ignition switch on.
(m)Measure the fuel pressure.
Fuel pressure: 265-304 kPa (2.7-3.1 kgf/sq.cm, 38-44 psi)
If pressure is high, replace the fuel pressure regulator.
If pressure is low, check these parts:
- Fuel hoses and connections
- Fuel pump
- Fuel filter
- Fuel pressure regulator
- Injectors
(n)Remove the Toyota hand-held tester.
(o)Start the engine.
(p)Measure the fuel pressure at idle.
Fuel pressure: 206-255 kPa (2.1-2.6 kgf/sq.cm, 31-37 psi)
If pressure is not as specified, check the vacuum sensing hose and fuel pressure regulator.
(q)Stop the engine.
(r)Check that the fuel pressure remains as specified for 5 minutes after the engine has stopped.
Fuel pressure: 147 kPa (1.5 kgf/sq.cm, 21 psi) or more
If pressure is not as specified, check the fuel pump, pressure regulator and/or injector.
(s)After checking fuel pressure, disconnect the negative (-) terminal cable from the battery and carefully remove the SST to prevent gasoline from splashing. SST 09268-45012
(t)Reconnect the fuel inlet pipe to the delivery pipe with 2 new gaskets and the union bolt.
(u)Reconnect the negative (-) terminal cable to the battery.
(v)Check for fuel leakage.
______________________________
Nov 11, 2020 at 10:36 AM
DOUGANDLAURA44
  • 16 POSTS
It does have a bit of fuel smell as I try to start. I will send a video once it has sat for a little while. But if I let it crank without pedal pushed in it tries to catch better but won’t keep running until i floor it. Second thing I just noticed today is at 75 mph I top out. I can floor it and it will not accelerate anymore and it won’t down shift. At 65 it will downshift just fine and rev nicely.
Nov 11, 2020 at 10:18 PM
DOUGANDLAURA44
  • 16 POSTS
Here is a video of the start. It misses when no gas, then when I floor it the catch starts to happen.
Nov 12, 2020 at 2:42 AM
  • 110,246 POSTS
Do me a favor. I want to see if it is a low fuel pressure issue. Do the following:
1) Turn the key from off to the on position (engine off) and count to five.
2) Turn the key off and then repeat step 1 three more times.
3) After you follow steps 1 and 2, see if it starts normally.
Let me know what happens.
Nov 12, 2020 at 11:41 AM
DOUGANDLAURA44
  • 16 POSTS
It did not help. And when it’s turning over when I push the gas pedal down it seems like the rpm slows down with the starter. Like I increase compression.
Nov 12, 2020 at 10:30 PM
DOUGANDLAURA44
  • 16 POSTS
I did replace the fuel pressure regulator as well.
Nov 12, 2020 at 10:31 PM
  • 110,246 POSTS
Do you have a live data scan tool? If you do, check the temperature signal from the sensor before starting it (cold engine) to see if it is accurate. If it is off, it could be causing an extremely rich fuel mixture.
Let me know if that is something you can do.
Nov 13, 2020 at 11:22 AM
DOUGANDLAURA44
  • 16 POSTS
A friend of mine does. He said I could use it Monday. What should the temperature be cold? Air temperature?
Nov 13, 2020 at 12:08 PM
  • 110,246 POSTS
Before starting the engine, it should be very close to the ambient temperature. For example, if it is 60°F outside, the sensor should indicate approximately the same temperature.
Let me know if I can help.
Nov 13, 2020 at 12:20 PM
DOUGANDLAURA44
  • 16 POSTS
So we plugged into the OBD 1 port, I got a code of C2849. From what I’m reading is it is the O2 sensor? Does that sound like something that could be the problem?
Nov 16, 2020 at 1:58 AM
  • 110,246 POSTS
An O2 sensor can cause an issue simply because it is what tells the computer how rich or lean the engine is running. However, I am not seeing that code for this year make and model. What did you find so I can review it and determine if it is relevant.
Nov 16, 2020 at 11:48 AM
DOUGANDLAURA44
  • 16 POSTS
A Tua ply I can’t find it now. One other symptom. It smells flooded. Then when I finally get it started and keep it about 1,500-2,000 RPM's it runs smooth as silk. But if I let off it wants to shut off until it’s warm. But while it’s warming if I press the gas pedal fast it almost shuts off.
Nov 18, 2020 at 1:03 AM
DOUGANDLAURA44
  • 16 POSTS
Actually*
  • 110,246 POSTS
Honestly, it sounds like a fuel pressure issue or a coolant temp sensor problem. Have you checked fuel pressure to make sure it is within spec?
Nov 18, 2020 at 12:28 PM
DOUGANDLAURA44
  • 16 POSTS
I put in a new fuel pump. Started right up. Drove it 25 miles to work and it sat for 8 hours. Tried to start and it did the same thing. I’m going to put a new battery in because I think this 4 year old one has about had it.
If the new battery doesn’t help, is there a way to check the coil packs?
Nov 30, 2020 at 6:42 PM
  • 110,246 POSTS
Yes, you can check the coils. Here are the directions. The attached pic correlates with the directions.
_________________
1997 Toyota Truck Tacoma Regular Cab 4WD L4-2693cc 2.7L DOHC MFI
Vehicle Powertrain Management Ignition System Ignition Coil Testing and Inspection Component Tests and General Diagnostics
Component tests and general diagnostics
Ignition coil inspection
1. Disconnect high-tension cords from ignition coils
2. Disconnect ignition coil connectors
pic 1
3. Inspect secondary coil resistance
using an ohmmeter. Measure the resistance between the positive (+) and high-tension terminals.
cold: 9.7 - 16.7 k ohms
hot: 12.4 - 19.6 k ohms
if the resistance is not as specified, replace the ignition coil.
4. Reconnect ignition coil connectors
5. Reconnect high-tension cords from ignition coils
_______________________________
Dec 1, 2020 at 10:53 AM
DOUGANDLAURA44
  • 16 POSTS
12.18 on one and 12.47 on the other.
Dec 2, 2020 at 7:05 AM
  • 110,246 POSTS
Is that the resistance with it cold? If so, the coil is out of spec. If it is when it's hot, it seems good. Did you check it both cold and hot?
Dec 2, 2020 at 10:08 AM
DOUGANDLAURA44
  • 16 POSTS
No, I just checked cold. But your message earlier said between 9.7 - 16.7 cold. I thought 12 would have been good cold?
Dec 2, 2020 at 11:39 AM
  • 110,246 POSTS
Yes, you are correct. That is within spec. I was asking because if it was hot, then it wouldn't have been.
You know, I'm going to mention your vehicle to the site owner. He is very good at diagnostics. Let's see if he has other ideas.
Dec 2, 2020 at 12:06 PM
DOUGANDLAURA44
  • 16 POSTS
Oh, okay whew. Thought I was going to have to buy new ones, lol.
Dec 2, 2020 at 8:46 PM
DOUGANDLAURA44
  • 16 POSTS
So I pulled the coils out completely and tested the secondary’s which came out in the 12’s.
When I tested the primary’s where the connectors plug in. I put the multimeter to the constant and then checked the other three prongs. I was getting 56.4 k ohms. I was reading that it should have only been somewhere around 6.
Dec 3, 2020 at 1:45 AM
DOUGANDLAURA44
  • 16 POSTS
Replaced both coils. It runs better. But it still was a hard start condition. Once it warmed up it ran like a champ. An hour and a half later I came out to start it and it seemed like it had some missed and low idle as it started up. But after I revved it for a second it ran okay.
Dec 3, 2020 at 9:44 AM
DOUGANDLAURA44
  • 16 POSTS
Okay Mr. Joe,
You are the man, so I don’t have an OBD2 or 1 port that is wired up properly so I couldn’t do any data reads. But you were 100% right. It was the coolant temperature sensor. It had a severed wire going to the plug. Truck is fixed and with all the nice new pretty parts it runs like a champ. Thank you for all your time.
Dec 4, 2020 at 9:06 AM
  • 110,246 POSTS
I'm glad you found it. You would be surprised how often that sensor causes trouble on all types of vehicles.
Regardless, I'm glad it's fixed. Take care of yourself. Also, please feel free to come back any time in the future. You are always welcome here.
Dec 4, 2020 at 12:31 PM
