Long crank when engine is warm, and Fuel pressure drops to zero after engine shut off?
148,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
DIDI7154
  • 30 POSTS
My truck starts right up in the morning but after I drive it, and the engine is warm it has a long crank to start. I checked the fuel pressure and when the engine is running the fuel pressure is good. As soon as I turn the truck off the pressure immediately drops to 0. I suspect there’s a leak in the pressure system somewhere. My thoughts are either the injectors or the fuel pump/pressure regulator/ check valve (all of which are part of one fuel pump assembly on this truck). How do I determine if the leak is at the injectors or the pump?
Oct 31, 2024 at 5:57 AM
  • 55,808 POSTS
If an injector is leaking, you will have an engine misfire. It does sound like the fuel pump is getting weak and even though you have good pressure when idling it might drop off while driving under load. Do you have any trouble codes? Here is a guide that deals with hard starting which we should go over for more information.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Fuel System Pressure .................... 339 kPa ± 34 kPa (49.2 psi ± 2 psi).
Is this what you got when testing? Please go over this guide and get back to us.
Oct 31, 2024 at 10:52 AM
