The car starts fine on the first start of the day or if it has been sitting for long periods of time. My problem is after car gets up to operating temperature it will not start or has long crank times. I've read about this issue until my eyes bleed and can't find a definitive solution to this problem. I've replaced the thermostat, fuel pump, all 4 spark plugs, 1 ignition coil that was bad and crankshaft position sensor. None of these things fixed or even helped the problem. Has anybody found a solution to this yet?
Jul 21, 2020 at 2:25 AM
