Locked gears
190,200 MILES • 1.2L • 4WD • MANUAL
TEEHAZIE
My car firstly had a weird sound when putting gear five, then I kept driving and its just had this loud noise from the passenger seat and all gears got stocked. Took it to a mechanic and a new clutch kit was putted , a new bush and gearbox oil was also putt in. After that loud sound from the passenger seat was reduced but now the problem with gears still remains. they are locked will not go to any gears.
Dec 7, 2017 at 11:35 PM
  • 55,758 POSTS
It sounds like you have a clutch issue. I have seen where the clutch throwout bearing pivot arm shears a lock pin causing the throw out bearing intermittently not depressing the clutch pressure plate. How does the clutch feel?
Here is a guide that can help:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Cheers, Ken
Dec 9, 2017 at 11:34 AM
TEEHAZIE
Hi Ken it is Hazel again, the problem is that in da gearbox fifth gear is stuck and lost neutral meaning the shafts rotates with the fifth gear while on neutral but R 1 2 3 4 gears are okay. we found a plastic plate broken inside fifth gear chamber.
Dec 10, 2017 at 1:53 PM
  • 55,758 POSTS
Nice work, so is it fixed now?
Dec 15, 2017 at 5:41 AM
