Lock cylinder will not turn
200,000 MILES • 6.5L • V8 • TURBO • 2WD • AUTOMATIC
RAYDEN
My lock cylinder went bad, the key would not turn the cylinder nor would the key come out. So I pushed the pin to release the old cylinder and it come out. I got a new one, installed it and still would not turn. I double checked for debris and made sure it was the correct part. All checked out, but the new lock cylinder will not turn. Any ideas?
Thank you so much.
May 22, 2018 at 1:33 AM
  • 55,710 POSTS
It sounds like the ignition switch down on the column has gone bad. Here is a diagram to help you see what you are in for when checking the switch. I would remove the switch and see if the lock turns.
Cheers, Ken
May 24, 2018 at 5:47 AM
RAYDEN
Thank you very much for the reply. I will give it a shot. Thanks again for the information.
May 24, 2018 at 5:49 AM
