Location temperature sensors
194,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MG STEEL
  • 18 POSTS
I was told there two temperature sensors and one is on the water pump in front of the engine but wasn’t able locate other one.
Dec 8, 2019 at 11:15 AM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the diagrams for the Engine Coolant Temperature [ECT] sensor, that is used by the vehicle's Power-train Control Module [PCM], or "computer", and a diagram for the Temperature Gauge Switch, which is used for the temperature gauge. I hope that this helps.
Thanks,
Alex
2CarPros
Dec 8, 2019 at 11:48 AM
MG STEEL
  • 18 POSTS
Started car and turned lights on and it shut off. so I started it again and look under the hood to see if might of come off but didn’t. looked at voltage meter inside the car it was fine, got home and tried it again had no problem.
Dec 12, 2019 at 9:08 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
This sounds like an intermittent electrical problem, which can be extremely hard to find, especially when it is not acting up. Get back to us when the problem raises it's head again, and we will try to fix it then.
Thanks,
Alex
2CarPros
Dec 12, 2019 at 9:59 AM
MG STEEL
  • 18 POSTS
Can you tell me, do the oil pressure gauge should be when car is off? do the needle supposed to go down or stay up?
Dec 12, 2019 at 10:32 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
The gauge should go down when the vehicle is shut off as there is no oil pressure.
Thanks,
Alex
2CarPros
Dec 12, 2019 at 9:32 PM
