Where is the VSS Output Sensor located?
153,000 MILES • 4 CYL • 2WD • MANUAL
GHOSTRIDER44
I need to replace the output sensor on the car, but I cannot find the location of the sensor for my transmission.
Thanks!
Sara
Jun 29, 2022 at 7:09 AM
  • 55,658 POSTS
It looks like the output shaft speed sensor is about halfway down the case on the passenger's side. here is the exact location in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 29, 2022 at 11:27 AM
GHOSTRIDER44
Are there any landmarks I can use to identify where it is? I think I found it, but I am not sure. That picture is much cleaner than my corroded engine.
Jul 10, 2022 at 4:17 AM
  • 55,658 POSTS
Lol yep, here is a better image. Check out the diagrams (below). Please let us know what you find.
Jul 10, 2022 at 6:36 AM
