location of the transmission speed sensor / sensors
174,000 MILES • 4.1L • V6 • 4WD • AUTOMATIC
BILLYG6381951
I am trying to locate the exact location of the trans speed sensors, I have looked searched for any diagrams on line to show / display the correct trans, but to no avail... my truck now is to the point when operated it will not up shift from the first starting gear, of course the abs lights ,check engine light , and brake lights are on...in closing I just want to make sure I am buying the right parts.
Respectfully,
Jun 3, 2015 at 8:33 AM
  • 110,248 POSTS
Are you referring to the vehicle speed sensor (VSS)? Is the speedometer working?
Jun 3, 2015 at 12:24 PM
