location of the downstream oxygen sensor
180,000 MILES
WOLFDOG1207
We have a 1995 Chevy Lumina car with a 3.1 engine, and we are unable to find the down stream oxygen sensor. We have looked under the car along the entire exhaust, and are still unable to find where it is located.
Jun 27, 2013 at 11:45 AM
  • 110,251 POSTS
Check near the catalytic converter.
Jun 27, 2013 at 11:47 AM
WOLFDOG1207
We have already under my car looking for this o2 sensor and looked right by the cat converter and still cant find it.
Jun 27, 2013 at 10:29 PM
  • 110,251 POSTS
It should be located on the exhaust. If you look in between the motor and the firewall you will see the upstream o2 sensor. If you crawl under the car and look behind the cat you will see the downstream O2. That is where the SHOULD be located.
I hope this helps.
Jun 28, 2013 at 1:03 PM
WOLFDOG1207
I found the one by the firewall, and followed the exhaust to the catalytic converter, and then followed the exhaust back, but I can still only find the 1 o2 sensor. Is it possible that I just have 1 o2 sensor?
Jun 29, 2013 at 12:30 PM
  • 110,251 POSTS
It is possible.
Jun 29, 2013 at 1:32 PM
