Location of the blend door actuator needed
2000 MITSUBISHI ECLIPSE
177,065 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DALE CARTER
Cannot find the blend door actuator.
Dec 22, 2016 at 5:43 AM
HMAC300
  • 48,601 POSTS
you cannot find it because you do not have one. you have a cable that moves an air mix door check for a broken cable, see picture.
Dec 22, 2016 at 8:19 AM
