Location of the crankshaft sensor
67,009 MILES • 1.6L • 4 CYL • FWD • MANUAL
IMTAZZ
Can not locate where the crankshaft sensor is located. if possible send pictures and details of where it is located, what it is by or under. I have tried forums it was not where anyone has said. if possible show or say where each end goes. I believe connects to side of distributor. please help!
Sep 16, 2017 at 2:50 AM
This is internal to the distributor. I am attaching the info that is needed to determine this and all the operation as to how things work.
Here is a guide that talks about crank sensor issues that will help you or others if needed:
Please see the items below for this detail.
Dec 20, 2020 at 1:19 AM
