Where is the coolant temperature sensor located?
2007 KIA AMANTI
99,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ALEXEI NIKOLAYEVICH
  • 15 POSTS
overheat temperature of engine.
Aug 28, 2021 at 12:12 PM
SQM
  • 6,383 POSTS
The coolant temperature sensor if located on the back of the thermostat housing on the right hand side of the engine (as you are facing the engine). See diagram below.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
So are you having overheating issues with this vehicle?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let me know of any questions.
Aug 28, 2021 at 1:56 PM
