I need to know the location of temperature switch and oil switch.
Nov 30, 2017 at 5:22 PM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
On G series vans the oil pressure switch is located drivers side rear of engine.
The temperature switch is drivers side of engine. Here are diagrams for both:
The oil pressure switch shows 2 possible locations so look at both.
Images (Click to enlarge)
Nov 30, 2017 at 9:10 PM
MANUEL ACEVES
MEMBER
Thank you I have located the oil pressure switch I need to know the location of the temperature switch not the temperature sensor from what I understand the temperature switch is feeding to wire feeding the computer and the temperature switch is for the temperature gauge I need to know the location of the temperature switch thanks
