Location of rear blower motor, actuator, & fuses
180,000 MILES • AUTOMATIC
KAYLA1RW
Where can I locate the rear blower motor
Aug 25, 2019 at 10:03 PM
  • 110,246 POSTS
Welcome to 2CarPros.
It is in the rear of the vehicle luggage compartment (passenger side). You will need to remove trim to access it. See picture 1. in the images below.
If you look at picture 2, it indicated the directions for replacing the motor. Picture 3 correlates with the directions.
Here is a link that shows how a blower motor in general is replaced. It may help.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Let me know if this helps. Check out the images (Below). Please let us know what happens.
Aug 26, 2019 at 11:58 AM
