Location of power window relay
163,000 MILES • 4 CYL • AUTOMATIC
GCRAFT
My power windows don't work. The fuses tested fine. There's no power getting to the window switch. I haven't checked the window relay yet because I can't find it. Where is it located?
Mar 31, 2016 at 1:34 AM
HMAC300
  • 48,601 POSTS
see pic also check at junction block if still no power after checking relay. also check both fuses
Mar 31, 2016 at 2:41 AM
  • 55,561 POSTS
The relay is located at the fuse panel on the left side of the dash. It will be labeled P/W relay.
Dec 2, 2025 at 2:22 AM
