Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Oil Pressure Sensor
Location
Location of oil sending unit
2013 FORD F-150
120,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
TLBRUCE
MEMBER
Oil gauge drops at idle.
Jan 1, 2019 at 12:55 AM
Experienced Mechanic
Good morning,
It is located under the alternator behind the oil filter adapter. I attached a picture for you to view.
Image (Click to enlarge)
Jan 1, 2019 at 1:01 AM
TLBRUCE
MEMBER
Thank you!
Jan 1, 2019 at 1:08 AM
You are welcome.
While you have it out, it would be good to check the actual pressure.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
You can rent one at a parts store.
Jan 1, 2019 at 1:12 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
