where is the odb output located?
200,000 MILES • 1.0L • 4 CYL • 2WD • MANUAL
PHICKS2121
I have an odb2 reader but cannot find the cable on the pickup. Is it a 2-pick connector by trunk pull latch?
Then to read code short out the an and b; power on; no start. Read flashes with table on site?
Fix issue then ; pull neg for 30 sec? Is this right?
May 19, 2023 at 3:42 AM
  • 55,647 POSTS
This is because this truck does not have a OBD2 port.
Here is how the codes are retrieved in the guide below:
https://www.2carpros.com/articles/odb1-isuzu-1985-1994-cars-and-trucks-code-retrieval-procedure-and-definition
May 19, 2023 at 5:37 AM
