Location of o2 sensor
60,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
STEVE2225
Not sure where it is located.
Jul 25, 2018 at 3:30 AM
  • 110,251 POSTS
This vehicle is not one that is available in the United States. As a result, all my manuals do not have this information. However, I still feel I can help you locate it.
On newer vehicles such as this, there is both an upstream sensor and a downstream sensor. The upstream sensor should be located in the exhaust manifold. The downstream will be in or near the catalytic converter.
The next three links describe how one works, how to check one, and how to replace one. These are general directions, but should be very helpful.
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Additionally, I have attached a picture of what one looks like for your vehicle.
I hope this helps you. Feel free to ask questions if you need anything.
Jul 27, 2018 at 1:41 PM
