location of ignition control module (icm)
240,000 MILES • 2.6L • 4 CYL • 2WD • MANUAL
BIGRED94
  • 9 POSTS
i keep looking every where online trying to find the icm and cant seem to get a good answer. if someone can help me that would be awesome! the best one ive seen is under the intake manifold but i would like to make sure its there before i start taking stuff apart.
Mar 10, 2018 at 12:19 PM
KHLOW2008
  • 41,812 POSTS
The ignition Control Module is within the distributor.
Mar 10, 2018 at 4:30 PM
BIGRED94
  • 9 POSTS
thats what i was thinking but when i look up the part by the vin number i get something completely different.
Mar 10, 2018 at 9:48 PM
KHLOW2008
  • 41,812 POSTS
Based on the model it should be equipped with a distributor and if that is so, then the ICM is within.
Mar 12, 2018 at 12:44 AM
BIGRED94
  • 9 POSTS
Sorry for the late response. I found the icm it’s above the starter. The module is in the distributer. In the picture you see the icm above the starter bolt.
Mar 16, 2018 at 9:54 AM
BIGRED94
  • 9 POSTS
You can get to it if you take the passenger front wheel off
Mar 16, 2018 at 9:55 AM
  • 55,770 POSTS
Is this an NPR or Trooper? I found this which shows the module under the coil pack
Check out the diagrams (Below)
Please let us know what you find.
Cheers, Ken
Mar 19, 2018 at 5:21 AM
92ISUZUJM
Hello - I am trying to locate the ignition control module on the 2.6 liter 4 cylinder, fuel injected engine on my isuzu pickup. I would appreciate any help you can provide. Thanks - John
Feb 21, 2021 at 11:10 AM (Merged)
SQM
  • 6,383 POSTS
The ignition control module for the 2.6L Amigo truck is located under the intake manifold, with the coil.
Isuzu calls it power switch/ignitor.
Dec 2, 2021 at 1:59 AM
