Location of ignition coil IC
477,638 MILES • 1.9L • 4 CYL • 2WD • MANUAL
ELIJAHADEGAHI
  • 22 POSTS
Please can you show me the location of the ignition coil IC inside the ECM please? two of my ignition coil is not supplying current to the plugs.
Apr 24, 2020 at 3:13 PM
  • 110,251 POSTS
First, this model isn't offered in the US, so I have no technical info. Also, the internals of the ECM are basically a printed circuit board (PCB). In most cases, they are not serviceable.
Are you looking for a schematic of the wiring to the ECM?
Apr 25, 2020 at 1:03 PM
