Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Aug 31, 2023 at 7:27 AM
JSDORN
MEMBER
are you saying the low side port is on the passenger side near the strut? Do i have to pull the wheel to see it? My other question was, how do I remove the front grill to check the condenser for leaks?
Sep 1, 2023 at 4:58 AM
✓Experienced Mechanic
Yes, you may need to remove the tire and the fender well. For the grill issue please create a new question. We only handle one problem per thread, please post your new question here, you must be logged in.
