Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Azera
Electrical
Fuse Panel
Location
Where is the headlight fuse located?
2007 HYUNDAI AZERA
100,000 MILES
JAMIE JONES2
MEMBER
1 POST
The headlights are no longer working, and I can't locate the fuse for the headlight to make sure it's not blown.
Aug 5, 2022 at 8:14 AM
Experienced Mechanic
There are two fuses, one for high and one for low beams. Additionally, each one has a relay. These things are located in the under-hood fuse box.
I attached two pics below. One shows the wiring schematic for the lights and the other shows the fuses and relays.
Let me know if this helps and what you find.
Images (Click to enlarge)
Aug 5, 2022 at 2:30 PM
Add image or video
Ask a new question
Engine won't start
Engine misfire
