Where is the Fuse for On-Board Diagnostic (OBD) located?
171,000 MILES • 6 CYL • 4WD • AUTOMATIC
KSAUTOHELP22
Engine light came on and attempted to have the code read. The code reader did not light up and was told the fuse was probably out. The car manual doesn't specifically say where this fuse is.
Sep 16, 2022 at 9:59 AM
  • 110,248 POSTS
The power supply to the DLC is provided by the cigarette lighter fuse in the under-hood fuse box. It's fuse 13 and is a 20-amp fuse.
If you look at pic 1 below, I provided the wiring schematic of the DLC and highlighted the fuse that sends power to pin 16,
When you check the fuse, make sure it is good. Also, make sure there is power to and from it.
See pic below. Pic 2 shows the fuse location.
Sep 16, 2022 at 3:01 PM
KSAUTOHELP22
I apologize for taking so long to respond. This worked and helped me very much.
Sep 21, 2022 at 5:11 PM
  • 110,248 POSTS
No problem whatsoever. I'm glad to know it helped. Please feel free to come back anytime in the future or if you have questions. You are always welcome here.
Take care and thanks for the update.
Sep 22, 2022 at 12:25 PM
