Location of fuel pump relay
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NIKKCO FORTNER
  • 6 POSTS
Car tries tries to start but will not run. disabled anti-theft and changed lock cylinder. clicking noise coming from front of motor and no dash light.
Oct 16, 2017 at 12:33 PM
STEVE W.
  • 15,420 POSTS
How did you disable the anti-theft? If it is not done correctly you can have problems.
The pump relay is mounted on a bracket with three other relays behind the strut tower. The pump relay is the second one in from the engine side.
Oct 16, 2017 at 12:40 PM
NIKKCO FORTNER
  • 6 POSTS
I cut the little yellow wire that was in the lick cylinder.
Oct 16, 2017 at 1:00 PM
NIKKCO FORTNER
  • 6 POSTS
Also did the ten minute thing.
Oct 16, 2017 at 1:01 PM
STEVE W.
  • 15,420 POSTS
That yellow wire is what tells the Pass-lock system what key you have. Cutting it means the system no longer registers a key at all.
Oct 16, 2017 at 1:20 PM
NIKKCO FORTNER
  • 6 POSTS
So doing the restart did no good. should i splice it back together and try the reset again? Could you tell me the right way to do it? i saw that it only controlled anti-theft and you could go without it, it was supposed to work and once i find the relay. is it true that if i put my finger on it and have someone turn the key if it clicks it good?
Oct 16, 2017 at 1:31 PM
NIKKCO FORTNER
  • 6 POSTS
Could you please tell me what i need to do and try at this point for tomorrow? i am working on this at home with little tools at my dispense.
Oct 16, 2017 at 1:41 PM
NIKKCO FORTNER
  • 6 POSTS
Before i even cut the yellow wire it would not start. i have put a different lock cylinder in it already.
Oct 16, 2017 at 1:44 PM
STEVE W.
  • 15,420 POSTS
The yellow wire sends a resistance value to the computer from the ignition cylinder.
You cutting the wire means the computer cannot read that value and shuts off the starting systems including the pump.
As the original did not work with the key I suspect the issue is not in the anti theft but in another part of the system. Reconnect the yellow wire then see if it does anything. Does the security light come on? I suspect it will as the new cylinder will have the wrong value. If it does try the reset you did the first time.
Is the check engine light on? If not the crank position sensor would be my first suspect, but not without testing it.
Oct 16, 2017 at 3:34 PM
