Can you tell me how to access the evaporator coil on a '99 alero. There is a leak in the system and I haven't found any leaks in the system under the hood. I need to get to the coil to check it and replace if necessary. I have the recovery machine. gauges and vacuum pump required to do the job. I just need to know where it is under the dash and how to get to it. Thanks.
Jul 12, 2015 at 12:06 AM
