Where is the crankshaft sensor located?
100,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
STEVE BECK
I'm trying to locate the crankshaft sensor on the vehicle listed above EX model with an inline 6-cylinder engine. Thank you very much.
Oct 12, 2022 at 3:34 AM
  • 55,684 POSTS
Sure, the crankshaft sensor is in the side of the engine block here is the location and instructions on how to replace it in the images below. Please let us know if you need anything else to get the problem fixed.
Oct 12, 2022 at 10:49 AM
