Crank sensor location is at the rear of the engine passenger side check fig(8).but you don't have fault code related to crank sensor.
Refer to fault code p2107 check fig (1)as a first step wiring between throttle body and engine control unit must be checked for short to B+ and B-. throttle body is already replaced as you mentioned. visually check throttle valve connector if wires overheated or sticked to each other, check for any sign of corrosion. check fig2,3,4 for wiring between throttle and engine control unit.
here is the link below for the procedure on how to check the wiring:
As the wiring diagram check for resistance and short circuit, check the wire between throttle valve connector pin 1 to engine control unit pin 68.and pin2 of throttle valve and engine control unit pin 67.
Fig 5 and fig 6 is the engine control unit connector and how it looks like, fig 7 is the location of the engine control unit.
Perform the wiring test and please get back to us with your results.
Images (Click to enlarge)
Jan 14, 2021 at 9:28 PM
