Bank two is on the opposite side of the engine from the #1 cylinder and it will be the first oxygen sensor before the catalytic converter. Here is a guide to help you change it out with the instructions for your car in the images below:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
I have included all oxygen sensor locations to avoid confusion. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Oct 12, 2022 at 7:10 AM
