Where is the bank 2 downstream o2 sensor located?
160,000 MILES • 2WD • AUTOMATIC
SKYLARJ
Is there anyway someone could send a description of where the downstream o2 sensor is located for the vehicle listed above limited model. I can’t find a video exactly showing, but I do see many comments saying it is more difficult to locate than on other ford edges. If someone could help it would be greatly appreciated, thank you. Attached is the code I got that we want to fix.
Apr 20, 2025 at 10:25 PM
STEVE W.
  • 15,381 POSTS
The bank 2 upstream is the sensor you see on top of the converter body, the downstream is in the side of the convertor. Bank one is set up the same.
Apr 22, 2025 at 4:06 AM
