Trying to locate the heated oxygen sensor bank 1 sensor 1 on my vehicle listed above LS model. My catalytic converter stolen. I had it replaced then CEL was on and now I'm getting codes P0130, P0135, and P0304. I was under the impression that the pre-cat upstream sensor would be just below the exhaust manifold but doesn't seem to be. Finding contradictory info online such as inside near the middle console and just under the heat shield. Neither seem to be accurate. If it helps I believe the engine is a 4G69. Thanks
Oct 17, 2022 at 5:23 PM
