location of PCM diode
130,687 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BENNANS
where is the PCM power diode located?
Feb 4, 2017 at 10:05 AM
HMAC300
  • 48,601 POSTS
it is in central junction box, but may be part of it and not serviceable. See picture.
Feb 5, 2017 at 12:55 AM
STEELWEELS
  • 60 POSTS
Computer problem
2000 Ford Expedition Engine Size unknown All Wheel Drive Automatic 120,00 miles
had just bought this used from a lot, and only has one key, the remote is broke, and i need to know where to locate the computer to get the manufacturers pass code to set the keyless entry numbers for our use. i bought a manual and it tells how to program, but doesnt mention where the computer or number is located.
Apr 23, 2019 at 10:22 AM (Merged)
  • 75,988 POSTS
The PCM is located under the dash on the passengers side by the blower motor, here are diagrams to show how to replace the PCM
Check out the diagrams (Below)
Cheers
