Throttle position sensor location needed
166,000 MILES • 2.4L • 5 CYL • 4WD • AUTOMATIC
GAVIN0427
i am trying to locate the placement on the throttle position sensor.
Nov 13, 2020 at 11:12 PM
You selected the 4WD so I assume you have the AWD model which means you have the 2.4L turbo? It doesn't appear to matter as it results to the throttle position sensor because your vehicle has what is called a throttle unit. Then the ECM uses the accelerator pedal position sensor for both the pedal and throttle position. Take a look at where it says that the pedal and throttle are treated like they are mechanically connected.
Let us know what the issue is that you are dealing with and we can see what other info you may need. Thanks
Nov 13, 2020 at 11:44 PM
GAVIN0427
just need location on vehicle of the throttle position sensor.
Nov 14, 2020 at 12:08 AM
Sorry if I was not clear, you don't have a traditional throttle position sensor. The ECM uses the APP signal and controls the throttle unit based on this. The throttle unit or Electronic Throttle Module is just an actuator that responds to what the ECM tells it to do. Here is the wiring diagram that shows just the throttle module.
Nov 14, 2020 at 3:04 AM
GAVIN0427
what I have is no acceleration when pedal to floor and the ETPS light came on.
Nov 14, 2020 at 3:50 AM
Okay. Have you checked for codes? If so, what was the code because that is going to tell us where to start.
Based on the way your system works this could be a pedal position sensor, throttle control unit (throttle body) or the ECM. So let's get the codes and go from there. Thanks
Nov 15, 2020 at 2:02 AM
