locating bank 1 sensor
60,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
ZH2021
check engine light is on and oil pressure gage bottomed out. not running hot pulled code and says Bank 1 replace. Is that the VTT sensor or Camshaft sensor ? Or are they the same thing ? and where are they located?
Jun 5, 2021 at 11:31 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It would help us better diagnose the issue if we know the actual code numbers. Here is a tutorial showing how to perform a CAN scan which can test all the systems on your truck including the check engine light you mentioned:
After you perform this get back to us with any codes and we'll help diagnose and provide you with all repair guides. Hope this helps and thanks for using 2CarPros.
Jun 6, 2021 at 12:55 AM
