Loud humming noise, possibly a wheel bearing?
167,000 MILES • 3.6L • 4WD • AUTOMATIC
GBOOTH58
Car has a humming from the passenger side. starts about ten MPH gets very loud. Thinking it a wheel bearing. any thoughts?
Apr 16, 2021 at 4:10 AM
HARRY P
  • 2,292 POSTS
Hello. At that age and mileage, a wheel bearing is very likely the issue. If you can get someone to ride with you, have theme sit in the passenger seat so they can feel vibration in the floor. They should feel the vibration changing with the speed of the car and sound. Also, being that the noise is coming from the right side, when you go around a curve to the right, the noise should quiet down some until you straighten out again. Also, it should get a little louder when you go around a curve to the left.
You might also have them sit in the back to make sure that the sound isn't coming from the rear.
I'm including some screenshots of AllDatas instructions on removing and replacing the hub. Generally, I recommend replacing the hub assembly and not just the bearing. By the time you pay a machinist to press the new beating into the old hub, you've spent as much money as you would have if you just bought the whole hub. You can get guns pretty cheaply from Amazon. I've had no trouble with Detroit Axle brand parts, so that's probably what I'd buy.
Apr 16, 2021 at 6:53 AM
GBOOTH58
Thanks.
Apr 19, 2021 at 2:41 AM
  • 55,688 POSTS
HEYMAN1104 is one of our best! Please let us know what you find. We are interested to see what it is.
Apr 19, 2021 at 2:42 AM
