Low-beam problems
240,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
GHOUL465
I have two problems. First, at night only when i am using my lo-beams, if I use my turn signal my high-beams will turn on and I have to wait until I turn to flip my high-beams on and off to get them to stop. Could this be a bad signal stalk? Secondly, as of two nights ago my low-beams stopped working altogether so I am stuck using my high-beams. Could this also be symptoms of a bad signal stalk considering my dimmer switch is located on the stalk?
Sep 22, 2016 at 1:27 AM
HMAC300
  • 48,601 POSTS
check fuses and relay for low beams under hood first then check ground for other things. however low beam can be a headlight module failure which I found in tips section. also check ground at base of battery which may have got battery acid on it corroding it.
Sep 22, 2016 at 2:30 AM
