LM7 into a 1970 FJ40 Landcruiser?
2003 GMC SIERRA
86,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RALPHIEADAMS
I am rebuilding a used 5.3L LM7 as per your (Ryan's) YouTube videos. I am at the point of figuring out where to connect the EVAP Vapor Canister Purge Valve Solenoid tube up to the heads toward the rear of the engine.
Mine is from a Wrecking yard so this tube is cut off.
I would like to install the EVAP equipment if I can reconstitute the system... But if it is too much trouble then I could be talked out of it. I am in AZ and it will be installed into a Vintage titled SUV so no need for emissions checking.
I have also retrofitted the fuel tank with a gm in-tank fuel pump with three tubes coming out of the top... one for fuel pressure to rails, one for vent to filler neck and the last one for evap cannister (I think...)???
Thanks!
May 20, 2023 at 11:58 AM
  • 110,244 POSTS
Thanks for watching the video. I will forward your question to Ryan. If you don't hear from him within two days, let me know.
May 20, 2023 at 5:05 PM
RYAN L
  • 272 POSTS
Hey there!
Thanks so much for watching the series! So, in this situation without needing emissions, I would not even worry about EVAP.
I would grab something like this:
https://tinyurl.com/yfxfec6z
Then just run a regulator from the feed side of the pump and have the return back to the tank. It is just a matter of running the fuel line up to the fuel rail and you should be good.
Thanks for using 2CarPros!
Best,
Ryan
May 22, 2023 at 7:28 AM
