Am I able to swap a 2012-2015 LFX 3.6 engine into my LLT 2010 Camaro?
Nov 28, 2022 at 11:51 AM
STEVE W.
✓Experienced Mechanic
The 2010-2011 are direct swaps, the 2012 and up are actually quite different, you would need to swap the exhaust, some wiring and the PCM at the least to make it work. GM changed a lot on the LFX version.
