1994 Chevy Camaro Engine Replacement
DWAXMONSKI
1994 Chevy Camaro 6 cyl
My husband and I are replacing the engine in our camaro when we took ours (engine) out we took it through the top but we had to take a lot off, like the exhaust and a few other things on the top of the engine. And I was wondering if it would be easier and faster to install it from the bottom. And if so what do we need to remove in order to install the engine from the bottom?
Oct 28, 2008 at 8:14 AM
TEAG
  • 158 POSTS
I woldnt even consider installing the engine from the bottom. My husband and I own a shop and all we do is F-Bodys (Camaros, Trans Ams, FireBirds, ect...). Installing the engine from the bottom requires alot more componants to be removed. Best bet is tp drop it right in from the top. If everything was labeled properly, you shouldnt have a problem just dropping that baby right in there. Good luck!! :)
Nov 3, 2008 at 4:30 AM
