Heater not working
KEN ELLIS
  • 2000 FORD TAURUS
  • 3.0L
  • V6
  • 60,000 MILES
Very little heat. Replaced thermostat, flushed, new heater hose to heater core, new blend door actuator. Flushed heater core.
Wednesday, October 31st, 2018 AT 6:27 PM
  • 52,797 POSTS
Good morning.
If your temperature is up at the hoses and you did all the work you described, it sounds like either the water pump is bad or the heater core is the issue.
What is the inlet and outlet temps of the heater core?
The impellers rot out on those water pumps and circulation is very low.
https://www.2carpros.com/articles/car-heater-not-working
https://www.2carpros.com/articles/replace-heater-core
Tuesday, December 29th, 2020 AT 11:05 AM
KEN ELLIS
Had not considered water pump. After looking at one at the auto parts store, this could very well be my problem. Just cheap sheet metal impeller. I will replace. Only thing left is blend door. Thanks for information.
  • 52,797 POSTS
You are welcome.
Always glad to help.
