1984 Lincoln Town Car Stalls When Braking
ANTHONYLEMONS
I bought a used 1984 Lincoln Towncar. For the first two weeks, it ran nicely, but recently, it began stalling whenever I put on the brakes, even soft braking. It would start immediately, and ran until I begin slowing down using the brakes. Any ideas? Thank you.
Sep 3, 2007 at 6:41 PM
  • 75,988 POSTS
[quote:a9e2086828="AnthonyLemons"]I bought a used 1984 Lincoln Towncar. For the first two weeks, it ran nicely, but recently, it began stalling whenever I put on the brakes, even soft braking. It would start immediately, and ran until I begin slowing down using the brakes. Any ideas? Thank you.[/quote:a9e2086828]
When was it last tuned-up?
I'll will say start with the PCV and EGR valve/to include vacuum leaks- When these things checks out-we'll go to the fuel system-checking the fuel pressure with a fuel gauge calibrated for yours.
Sep 3, 2007 at 9:28 PM
Suggested Repair
Confirm when the car was last tuned up. Inspect the PCV and EGR valves and check for vacuum leaks. If those are okay, test fuel pressure with a gauge calibrated for this vehicle.
Conversation Summary
The owner of a 1984 Lincoln Town Car says it ran well for two weeks, then began stalling whenever the brakes were applied, even during light braking. It restarts immediately and continues running until the brakes are used again. The expert asks about the last tune-up and recommends checking the PCV and EGR valves and vacuum leaks first, then testing fuel pressure if those checks are satisfactory.
