Lincoln Towncar
LINCOLN TOWN CAR
COUNTRYGIRL22
1997 Lincoln Towncar
140,000
4.6
Car feels like it darts back and forth. Have changed all ball joints , idler arm and pitman arm. Have new tires and also had car lined up after changing joints. Please Help!!!!!!!!!!
Nov 19, 2007 at 8:43 AM
BMRFIXIT
  • 19,053 POSTS
[quote:17aeae53f4="Countrygirl22"]1997 Lincoln Towncar
140,000
4.6
Car feels like it darts back and forth. Have changed all ball joints , idler arm and pitman arm. Have new tires and also had car lined up after changing joints. Please Help!!!!!!!!!![/quote:17aeae53f4]
check steering box
you mean left right no center
Nov 19, 2007 at 9:44 AM
COUNTRYGIRL22
[quote:68ee2278a2="BMRFIXIT"][quote:68ee2278a2="Countrygirl22"]1997 Lincoln Towncar
140,000
4.6
Car feels like it darts back and forth. Have changed all ball joints , idler arm and pitman arm. Have new tires and also had car lined up after changing joints. Please Help!!!!!!!!!![/quote:68ee2278a2]
check steering box
you mean left right no center[/quote:68ee2278a2]
Yes, seems to go one side to the other. Steering box has been checked. When holding steering wheel with both hands you can feel it constantly moving back and forth a little. Then when you hit a rough spot in road it darts back and forth. Any other suggestions??
Nov 20, 2007 at 3:39 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c46a7f67fb="Countrygirl22"][quote:c46a7f67fb="BMRFIXIT"][quote:c46a7f67fb="Countrygirl22"]1997 Lincoln Towncar
140,000
4.6
Car feels like it darts back and forth. Have changed all ball joints , idler arm and pitman arm. Have new tires and also had car lined up after changing joints. Please Help!!!!!!!!!![/quote:c46a7f67fb]
check steering box
you mean left right no center[/quote:c46a7f67fb]
Yes, seems to go one side to the other. Steering box has been checked. When holding steering wheel with both hands you can feel it constantly moving back and forth a little. Then when you hit a rough spot in road it darts back and forth. Any other suggestions??[/quote:c46a7f67fb]
IF ALL CHECKED OK
u need a new steering box
its loose on the inside
have u also check the shocks
Nov 20, 2007 at 4:40 AM
