1994 Lincoln Town Car Engine Knock
BASKETBALL3548
I have a 94 Lincoln Town Car its has roughly 135000 miles on it it ran great until i let it sit a month then i noticed it had no oil so i put 3 quarts in it and went to work and back about 28 miles round trip by the time i got home my oil light was on and it had this terrible knocking noise so i put more oil in it which was 10w 30 i believe and that knocking is still there it sounds as if its coming from the passenger side in the front of the engine near the spark plugs when i press the gas it gets louder and louder when i got on the ground i noticed i had an oil leak also but not in the normal spot its leaking from around the middle of the car underneath not up by the oil pan but further back does anyone know what this could be or what i could do to quite the knocking thanks for anyhelp
Sep 17, 2007 at 5:50 PM
  • 75,988 POSTS
[quote:fd08231669="basketball3548"]I have a 94 Lincoln Town Car its has roughly 135000 miles on it it ran great until i let it sit a month then i noticed it had no oil so i put 3 quarts in it and went to work and back about 28 miles round trip by the time i got home my oil light was on and it had this terrible knocking noise so i put more oil in it which was 10w 30 i believe and that knocking is still there it sounds as if its coming from the passenger side in the front of the engine near the spark plugs when i press the gas it gets louder and louder when i got on the ground i noticed i had an oil leak also but not in the normal spot its leaking from around the middle of the car underneath not up by the oil pan but further back does anyone know what this could be or what i could do to quite the knocking thanks for anyhelp[/quote:fd08231669]
You fried the engine bearings-you can put gear oil to it, to lessen the knocking and go sell it. Its a done deal or get a crankshaft kit.
Sep 17, 2007 at 7:43 PM
Suggested Repair
The expert concluded the engine bearings were damaged by running with little or no oil. Heavier gear oil may only reduce the knock enough to sell the car; otherwise a crankshaft kit is the repair discussed.
Conversation Summary
A 1994 Lincoln Town Car with about 135,000 miles sat for a month, was found nearly out of oil, and developed a loud knock after a short drive even after more 10W-30 was added. The noise seemed to come from the passenger front of the engine and grew louder with throttle, and oil was leaking farther back underneath the car. The expert said the bearings were ruined and suggested gear oil only to lessen the knock for sale, or a crankshaft kit.
