Dead Battery, Dead Doors
DHICKSELP
I am trying to help a friend of mine open her car. It is a 1993 town car. It has been setting for long time and now has a completely dead battery. When I turn the key in the door nothing happens and of course the push button does not work. Any ideas how I can open the doors or the hood? Thanks
Nov 7, 2006 at 10:56 AM
MANINDER
  • 7 POSTS
is there not a key hole in the door? and did you try to pull some cables through the grille? i thought of that don't know if you can reach them though my grille has alot of space to send hangers and stuff though might have to break into the car:(
Nov 30, 2006 at 10:11 AM
LSUSSEL
  • 252 POSTS
What happens when you insert the key into the key hole on the door?, its all manual so it should open right up.
Nov 30, 2006 at 2:06 PM
CORVETTE4+3
  • 22 POSTS
put the key in the door and turn to the right it may be a little hard to turn because it sat so long but should turn and open i know i have keyless entry also and i left the dome light on it kill the battery i open the door manually pop the hood to put a charge.
good luck
May 16, 2009 at 2:43 PM
