Thanks
1989 Lincoln Town Car Battery Acid Overflow
Thanks
Guess I'll have to take it in to have it checked out tomorrow at the dealer...thanks
Update...
I just measured the voltage of the battery with key off and it is 12.7...then with engine running 14.5....
then I tested 3 of my other vehicles and I got real close results...
Any other suggestions?
Update...
Any other suggestions?[/quote:52821c61c3]
14.5 does not sound that high from an altenator. Does it increase with RPM's?
I would suspect it may increase voltage while you are running faster than idle. I would check that. Another option is they could have overserviced the battery, however that is very unlikely.
when the battery is being overcharged, usually there is a very stong sour egg smell. If your tests results show the altenator is not over charging, then you may have a bad battery. Either way, the warrenty's on both should easy the pocket book.
Good luck.
Update...
Any other suggestions?[/quote:0bee7596f8]
Good luck.[/quote:0bee7596f8]
Thanks,
called the battery manufacturer and they said it was probably a little over full and that it ran out and leveled off and I opened the caps on top and it was at a normal level now and it didnt overflow after I drove for 2 hrs today...and also the alternator keeps the same voltage at higher rpms..thats what the voltage regulator is for right?so I'm guessing its not the alternator nor a bad battery since it hasn't overflowed again :)
thanks, I flushed the area with a lot of water.
Suggested Repair
The charging voltage of about 14.5V, stable at higher RPM, is normal, so the alternator is not overcharging. The battery was likely slightly overfilled and vented excess electrolyte until it leveled off. Clean the spilled acid with baking soda and water to prevent corrosion, and monitor for further venting.
Conversation Summary
A 1989 Lincoln Town Car had repeated dead batteries until a new OEM alternator was installed. After a drive, acid came from the battery vent cap. Voltage was 12.7V with the key off and 14.5V running, similar to other vehicles and unchanged at higher RPM. The battery maker said it had been slightly overfull and had leveled off; it did not overflow on a later drive. The expert agreed the issue was resolved and advised neutralizing the spilled acid with baking soda and water.
