The left low beam head light will not turn off even after the switch is off as well as the ignition. I pulled a few fuses until it went off to see what it might be. I found that it went out when I pulled the 15A fuse from the "LCM (High Beams), Multi-Function Switch (Flash-to-Pass)" slot. I haven't been able to find any other information on what this might be. If you can help it would be much appreciated.
Sep 14, 2010 at 11:18 PM
